Some specs needed
Hi, i am rebuilding my 2.7 to 2.7RS specs minus the MFI, using Webers.
Id need the specs of the following:
angle for 3-angle valve job
valve seat specs
valve measurements (tolerance) specs
Thanks!
PCA Member
2009 Audi A3 2.0 Quattro
1978 911 SC Targa
Old 02-22-2003, 10:16 AM
No Expert
jgparker's Avatar
valve seat angles: 30,45,75
valve seat specs: 1.5+/-0.1mm contact surface, and
47.5mm valve stem end to shim cavity length
valve specs: (head diameter, stem diameter, length)
intake: 46+/-0.1mm, 8.97-0.012mm, 114+/-0.1mm
exhaust: 40+/-0.1mm, 8.95-0.012mm, 113.5+/-0.1mm
I don't have the head margin spec handy.
-- Last Engine rebuild project, Now a coffee table.
-- New engine rebuild project, Alive and well.
-- '72 911 Martini RS, '69 911E Targa, a 2004 Cayenne S, and a Miata too... Looking for a Cayman S
Old 02-22-2003, 12:04 PM
