-   -   What the latest on break in oil considering new formulations? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/968434-what-latest-break-oil-considering-new-formulations.html)
John McM 09-02-2017 12:45 PM
Down under we don't have those oils. This seems like it fits what's being said though. Penrite Oil | RUNNING-IN OIL 15W-40 (Mineral)
txhokie4life 09-04-2017 09:28 AM
Planning to use the Driven product.
Which viscosity do you use for a 3.8 race engine break in?
Mahle jugs and pistons, new cams, clevite coated main and rod bearings?
Mike
Sboxin 09-04-2017 12:08 PM
Mike
Mike,
EDIT 15-50 weight "conventional" Joe Gibbs Driven break in oil - for the 20 minute 2000 RPM
cam/lifter break in - important to let engine cool down completely
and then next day track accel/decel piston ring/cylinder break in
- 4x 20 minute sessions
Then the Valvoline 20-50 for one race day - 4x 20 minute sessions
For the 3.8L race engine 2012 - JE 102mmx12.5:1 3.8 p set with Goetze rings
Reconditioned/recoated cylinders from 100 to 102MM by EBS
Cams - Webcams 20/21 with reconditioned lifters, EBS valve springs, etc
We went to the Clevite rod bearings after an engine refresh late in 2016
Regards,
faapgar 09-05-2017 05:48 AM
Hi,I have used Valvoline non-detergent 30W for 40 years for the 1st 500 miles.Then do a leakdown test.If good change to a regular oil of your choice.No synthetic in the 1st 5000 miles.Fred
