-   -   need help with engine rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/970840-need-help-engine-rebuild.html)
hcoles 09-25-2017 06:38 AM
Originally Posted by rgmrgm (Post 9747237)
I do not like the engine stands with 3 wheels and a T shape base. They are unstable regardless of the weight rating. the 4 wheel H shaped base stands are much more stable
+1 on this
Flat6pac 09-25-2017 09:58 AM
Sound of experience you must have had one fall.
I ve tripped over the fourth leg before....
Bruce
Tippy 09-25-2017 10:25 AM
You don't need a yoke. Tore down and built mine the 1st time on a table.
Is a yoke nice? Yep. But it's not a requirement.
ChrisBennet 09-25-2017 11:30 AM
There is another reason to skip the "T" style engine stands: they are hard to mount a catch pan on top of the legs. With "heavy duty" 2 leg style, you can place a couple of boards across the legs and put your drip pan on top.
bpu699 09-25-2017 11:34 AM
You don't need a lot of stuff, but it sure is nice... Such as impact gun, engine hoist, Dremel, air compressor, etc...
i can't imagine not having an engine stand, and therefor the yoke... Plus, you can sell it later if needed...
911pcars 09-26-2017 03:36 PM
Affirmative. There's a reason all terrain vehicles (ATVs) now have 4 wheels instead of 3.
Tippy 09-26-2017 06:02 PM
True. The only tool I bought that was 100% needed since my homemade one failed was the cam holding tool.
