Part number needed for RSR rocker shaft seal
Guys
Wayne's book reccomends using the RSR version and not the original. What's the part number for this ? Thanks Frank
Gold71 |
Find one of my prior threads. Some other guy found o rings that work...
$60 for some tiny gaskets seems hard to absorb... |
911 099 103 52
Chris Carroll TurboKraft, Inc. Tel. 480.969.0911 email: info@turbokraft.com http://www.facebook.com/TurboKraft - http://www.instagram.com/TurboKraft |
Designed to help solve a very specific problem: oil leaks between the rocker shafts and the camshaft housings. If $100 keeps your 911 from leaking, that's a helluva bargain.
Especially if your alternative is new rocker shafts or replacing camshaft housings.
Chris how often do these leak? Is this recommended on all rebuilds?
We do them on every engine we build, figuring it's cheap insurance
Every little bit helps on these engines when oil leaks are the bane of 911 ownership.
Thanks guys...
Also found them for $2.25 each on ECS. Thanks for comments and info Frank
Gold71 |
We put them on every build we do as well. Cheap insurance. Did they all need it? Don't know. But we know none of the motors ever leak...
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I tried but they just sheer off when I tried installing some on my engine.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Fitted to the groves in the shaft they have always slid right in to the bores. We had some a few years ago that would get a "haircut" when we inserted them but we don't source from that vendor any more. We do install the shaft with a light coat of oil as well.
