-   -   Help identifying engine, where to look for numbers? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/972753-help-identifying-engine-where-look-numbers.html)
infinkc 10-05-2017 10:22 AM
I have been cleaning up my late dads storage and found this engine the other day. Quick glance I didn’t see any numbers stamped, so not sure where to look.
Any insight on what year/model it is.
infinkc 10-05-2017 10:23 AM
http://forums.pelicanparts.com/uploa...1507224184.jpg
http://forums.pelicanparts.com/uploa...1507224210.jpg
proporsche 10-05-2017 11:25 AM
Search is you answer....the number you are looking for are here look..where is the finger and also where is the circle
Ivan
http://img.pccreation.net/photos/201710052024333101.JPG
JT912 10-06-2017 12:03 PM
Ivan
Unless it is a 914/6 motor.
proporsche 10-06-2017 12:18 PM
Hi to Oregon..maybe you could show him where the 914/6 number would be ..or??
Ivan
Flat6pac 10-06-2017 12:38 PM
914/6 number s located by the thermostat and case breather.
Bruce
JT912 10-06-2017 01:57 PM
From our host.
Pelican Parts: 914-6 Engine Serial Numbers
Image courtesy of the interweb.
http://forums.pelicanparts.com/uploa...1507323393.jpg
proporsche 10-06-2017 02:23 PM
so, what gives it away as a 911 engine is the oil pressure switch partly covered.the 914/6 has an oil press sending unit in its place.So it is a 911 ..which one, to be continued
Ivan
infinkc 10-07-2017 08:03 AM
Ok it says 6196145 on the block.
proporsche 10-07-2017 09:21 AM
and the number where the circle is? something like 901/16....?the other number points to 1969 911T
ivan
infinkc 10-07-2017 05:18 PM
ivan
Ok, other numbers are
901/16
21729
proporsche 10-08-2017 12:03 AM
so here you have it it is 1969 911T...
Ivan
