Question Camshaft Timing
Over the years, my appreciation for engines has evolved from Volkswagon, to Corvairs, and now to Porsches. I am now rebuilding my 1st 911 engine ("73 Targa).
My question is concerning the camshaft timing. Is there any way to achieve this without buying a dial gauge. Its not the cost of the gauge, I just don't have one and would like to complete the assembly this weekend.
Any suggestions?
Old 02-07-2003, 01:55 PM
If I understand your question correctly:
You can "rough time" the engine by setting it to TDC and then setting the cams up so that the markings point up also.
However, this is the starting point for timing with the dial gauge, and you can NEVER start up the engine this way
Looks like a dial gauge purchase is in your immediate future
Old 02-07-2003, 04:27 PM
Thanks. I'll find one before I go any further.
Old 02-07-2003, 04:31 PM
Cam Timing
Vouvray,
You definitely need a dial gauge to correctly set the cam timing. One place you can get decent dial gauge set is from Harbor Freight. You would never be able to set it correctly without this instrument. Good luck.......
Old 02-07-2003, 05:37 PM
JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Vouvray,
I received some very good additional advice on cam timing some time ago. Here is the link: Help--Cam Timing
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 02-10-2003, 10:38 AM
Thnks for help, Wayne.
BTW, does Pelican have a printed catalog available?
'73 911 Targa (Project Car)
'68 Meyers Manx Dune Buggy (Corvair Powered)
'02 BMW 330i (Wife's Car)
Old 02-10-2003, 12:03 PM
Question
OK, I really do believe after reading the relevant authorities that you can't do this without the full rigamarole of dial gauge, etc. I look forward to learning the procedure when I rebuild my engine.
What no one has yet told me is WHY this is necessary. If you have a TDC reference mark on the crank and similar marks on the cam sprockets, how is the uncertainty introduced into the system, thus needing a more precise final adjustment? Any other cars that use this procedure?
David Porter
Glyndon MD
'72 911T Targa
Old 02-21-2003, 02:39 PM
You could probably time the cams w/o a dial indicator, but Porsche's setup allows precise settings. Why chance the timing to a mark on the end of the camshafts?
In addition, you're timing two banks of an opposed engine. The chances of getting the two out of synch are greater than a Vee or inline engine with a single cam sprocket and mark.
For that matter, does everyone assume the mark on the crank pulley indicates exact TDC?
Sherwood Lee
http://members.rennlist.org/911pcars
Old 02-21-2003, 04:28 PM
Banned
snowman's Avatar
Note. YOu must also find the TRUE tdc mark on the pully. The factory mark was off by over 3 degrees in my case. TO find the true tdc use a positive piston stop and a degree wheel along with a dial indicator. The piston stop is inserted in the spark plug hole or if the head is off on the top of a the number one cylinder. The engine is rotated to stop on the insert, the degree noted. The engine rotated ccw to the stop and the degree noted. True tdc is halfway between the two degree noted. THIS is the ONLY way to really get the correct tdc. Other ways will be slightly less accurate.
Old 02-24-2003, 11:00 PM
Superman,
Just the answer I was alluding to. This is good info. Most DIY rebuilders (I think) skip over this important check.
I've done this w/o the cylinder head. With the head installed however, the piston stop might interfere with the intake and exhaust valves at the TDC, overlap position. What do you think?
Sherwood
Old 02-24-2003, 11:46 PM
Banned
snowman's Avatar
Thumbs up piston stop
I modified a spark plug by cutting off the tip and glueing on a short piece of aluminum rod about 3/4 of an inch long. Nothing seemed to interfere with it contacting the piston. making a stop that can be used without the head on works just as well. Warning be carefull, very carfull not to crank the engine to hard or use the starter to turn it over when the piston stop is screwed in or you will have a hole in the piston. Remove all spark plugs first, use the smallest wrench that you have to turn the engine and be as gentle as possible when contacting the piston stop. If you have any doubts about your ability to do this proceedure, don't.
Old 02-26-2003, 12:21 PM
