Unknown Pipe on 3.1 rebuild
Hi. Just wondered if anyone could help me identify this pipe and where it goes. This is the only outstanding thing and for the life of me I can't remember or find out where it should connect. It's on the right-hand-side of the engine
Thanks very much
Old 10-22-2017, 08:18 AM
Oops! Sorry, 3.2 rebuild
Old 10-22-2017, 10:01 AM
I don’t recognize the shunt but that size hose generally goes to the carbon canister in the wheel house on the Carrera.
Bruce
Old 10-22-2017, 10:59 AM
that connection is just an intermediary between the same type of hose. You should find another hose just like it and they connect at the same point.
Mine runs along the right rear frame edge of the engine bay just below the oil filter and in front of the right rear shock mount.
1987 Porsche 911 Carrera Coupe
Old 10-22-2017, 04:04 PM
Bruce
yes... the other hose goes to the carbon canister... so the hose goes from the carbon canister into that 'shunt' with another hose clamp to hold it on
Old 10-22-2017, 04:06 PM
Or on the Carrera, the same size hose runs from the front of the throttle body to the vacuum diaphragm coming off the oil tank.
Bruce
Old 10-22-2017, 07:01 PM
Thanks Everyone for the advice. I will take a look soon and see if I can finally say it's all back together
Regards from Dallas
Mike
Old 10-23-2017, 03:38 AM
Tags
3.2 , engine , pipe
