-   -   Trakrat's 3.2 Engine Rebuild (http://forums.pelicanparts.com/911-engine-rebuilding-forum/974356-trakrats-3-2-engine-rebuild.html)
Trakrat 11-08-2017 02:40 PM
Originally Posted by bpu699 (Post 9807961)
Do you have any dewalt tools and chargers already? Any other manufacturers battery or chargers handy?
If so, go on ebay and get yourself an impact wrench. About $110 refurbed ($300 new)...
You will find a million uses for it...
Have you gotten to the exhaust nuts yet?
Bo
well... perhaps my impact wrench is weak. I went through the entire battery charge on all the nuts and not one of them budged.
I'll keep spraying with PB Blaster and let it soak overnight.
Trakrat 11-08-2017 02:56 PM
Originally Posted by faapgar (Post 9806631)
Hi,maybe my wife made me the wrong batch of brownies this morning and I am FUBAR here on the beach in C.R.but the previous post said chain sprockets and wear looked good on the right side which is 4-6 cylinder.Right side chain sprocket is installed backwards and the small chain sprocket does not look so good to me.I would question everything from the previous build.I just finished a 3.0 Carerra engine for Nathambs in September that had the left side & right side reversed and it ate the aluminum intermediate shaft gear.Fred
very interesting... glad you noticed.
Trakrat 11-08-2017 03:03 PM
And now.... the damage to the pistons....
Piston #1
http://forums.pelicanparts.com/uploa...1510185797.jpg
Piston #2
Piston #3
Flat6pac 11-08-2017 03:14 PM
looks like 993 dilivars,
I just use a breaker bar on the 10 mm because some times my snap on impact doesn’t do it.
Bruce
Trakrat 11-08-2017 04:19 PM
Bruce
thanks.. I'll keep that in mind when it comes time to remove the studs.
faapgar 11-08-2017 04:21 PM
piston marks
Pistons do not look too bad.Good to look at the rod bearings as they can get a flat spot from contact.An egg carton works great to lay out the rocker arms in order 1-6 from left to right.Keep digging.Fred
Flat6pac 11-08-2017 04:56 PM
993, the point being, why would you remove them?
When they were purchased there was a loctite on the threads that activated from the heat of the threading install. You ll need a torch to remove them and exact replacements are near $50 each
Bruce
Trakrat 11-09-2017 12:07 PM
Bruce
Why would I keep them? I have no idea about what was installed, when it was installed, who installed them. Plus... I wouldn't want to ship my case halves all the way across the US and shipped back again and trust that nothing happens to the studs during shipment, handling, etc...
I also planning on replacing all fasteners with Raceware (head studs, rod bolts, etc...)
Trakrat 11-09-2017 12:21 PM
took out the right side camshaft.
This camshaft was VERY DIFFICULT to pull out. the 3rd bearing seemed to get stuck... after about 15-20 minutes of playing with it, I finally was able to pull it free.
Anyways... posted some pics that made me curious about what some of you experts may be able tell me about it.
What are the numbers? What does it tell you? Also... what's your opinion of the bearing surfaces?
http://forums.pelicanparts.com/uploa...1510262471.jpg
bpu699 11-09-2017 02:36 PM
My search suggested super tech is preferred for heads, arp for rods. Race ware had some negative comments...
If you have 993 head studs, those are highly rated. Leaving them saves you $1000 as that's about what they cost. I believe they are considered top of the line, but will let experts chime in...
Why are you shipping your case cross country? What's wrong with it?
Trackrash 11-09-2017 03:03 PM
^ +1
Unless there is a known issue with your case, why do anything but clean it? Those 930 cases are usually bullet proof.
Trakrat 11-09-2017 03:14 PM
nothing wrong with it.. (at least that I can tell). I was thinking of having it boat-tailed.
Trakrat 11-09-2017 03:17 PM
Originally Posted by Trackrash (Post 9809337)
^ +1
I was planning on having it boat-tailed.
bpu699 11-09-2017 03:18 PM
I'm not sure what your budget is...but it must be pretty impressive... Some of the parts prices, before upgrades, are eye watering
Trakrat 11-09-2017 03:36 PM
well.. my budget is not that impressive... trying to save costs as much as I can.
The other problem is that I don't have any local shops in my area... at least none that seem to know what they're doing to even clean my case and stuff.
Besides that... all my machine shop work is going to be done by Ollies, so figured I might as well send them everything. :D
Flat6pac 11-10-2017 03:18 AM
From what I’ve read, you’ll get it all back someday....
Bruce
Trackrash 11-10-2017 06:54 AM
Just don't tell your wife.
http://forums.pelicanparts.com/uploa...1510329249.jpg
Heck, you can boat tail with your drimmel.
Trakrat 11-10-2017 12:11 PM
Is that the before or after pic?
I need to get all my oil lines internally cleaned too, as I have some metallic 'dust' showing up in my oil.
Trakrat 11-10-2017 12:13 PM
Bruce
hmmm.... what do you mean?
Trackrash 11-10-2017 12:59 PM
Here is a better shot after. I should mention that I cleaned most of the gunk off before I put it in the dish washer. Later I pulled out the large end plug on the gallery to make sure there was not gunk in there. I also was not trying to polish my case. Just make it look clean.
http://forums.pelicanparts.com/uploa...1510351157.jpg
KTL 11-10-2017 03:33 PM
I think he means their turnaround time can be quite long. But i'm guessing he may be thinking of another Porsche machine shop with the initials CE.
Trakrat 11-12-2017 12:32 PM
I hope so. My biggest fear is sending out all my parts to a machine shop and having the parts 'disappear'.
Unfortunately I have bad karma when it comes to customer service so it makes me nervous to send everything and have it left there for months.
KTL 11-13-2017 06:43 AM
I don't think we hear those kinds of stories about Ollies. But i'm obviously not privy to everything everybody does with them. Nonetheless throughout my years here on the forum I don't recall hearing any "I sent them my stuff months ago and haven't heard boo since" stories about them. Their reputation is really good and well deserved.
twickes 11-13-2017 08:51 AM
Ollies is amazing. You have nothing to worry about unless you "need everything right now." They're lead time is about 2-3 months.
75 911s 11-13-2017 08:53 AM
FWIW. Heard a lot of good things about Ollies as well when I researched my 2.7 rebuild. Also lead time increases over winter months due to all the winter projects in cold climates.
bpu699 11-14-2017 06:37 AM
Weird. I got my rods back in a week... Very pleased with the workmanship. Shipping was a tad high and they only do COD which added cost...
That was a month ago...
Trakrat 11-14-2017 01:37 PM
So how exactly does COD work? I'm confused on that... do you send them a check in the mail and once it clears they ship everything to you?
I'm only familiar with this process back in the early 90s when I would drive down to the local USPS to pick up something that required payment there.
bpu699 11-15-2017 04:26 AM
Driver rings your doorbell, you hand them a check. It adds about $30 to the shipping amount. So shipping/COD was about $80.
The cost of the machine work was reasonable. More than the local guy wanted, but I really wanted a Porsche expert to do it. Its not like I can just go out and buy another set of rods cheap if a mistake is made.
Until this purchase, I haven't paid COD in 30 years. I wonder why they don't accept credit cards? I would think the risk of a bounced check is much greater than that of a credit card payment...
But the work was spot on best I can tell, and turnaround was fine. Maybe the longer waits are seasonal?
KTL 11-15-2017 08:15 AM
I've bought a few sets of gears from a great fella Steve Alarcon here on the forums. Reason he does the COD, and not just because he's old school, is he wants the buyer to see the parts before paying. So if you aren't happy with what's delivered, you refuse the delivery and keep your money
I think COD also has to be certified payment and not just a personal check? My purchases with Steve were a big chunk of money so it made sense to use a cashier's check from my bank.
Trakrat 11-16-2017 07:04 AM
Ok all... latest update. I'm hoping to split the case and loosen the rods next.
Also....
I'm getting ready to ship out parts to Ollies.
I've called there twice and they are ALWAYS informative, communicative with me, and patient with all of my questions.
So I'm going to ship the following to them:
Cam Towers
Camshafts
Pistons & Cylinders
Rods
Heads
Case
Crank
Flywheel
Clutch cover
pulley wheel
fan
fan housing
valve covers
timing chain covers
oil cooler
oil pump
Pretty much the entire engine. :eek:
A few of reasons for sending them so much stuff:
1. I don't have anyone local (that I trust) who does any machine/cleaning work.
2. I've found some metallic 'dust' in my oil as its been draining from my engine, so I am going to need every oil channel cleaned thoroughly.
3. I also need some things cleaned via bead blasting. Apparently Ollies does a 2 step bead blast process that helps seal the surface to keep from corrosion.
4. As for the camshafts, they do business with Web Cams and can help communicate (translate) my idea for power delivery to Web Cams to profile them correctly.
As for #3, I contemplated just having someone local to do the media blasting. However, after searching on these forums, I found quite a few pictures of people having their fan blades pitted and broken from a poor blasting experience. I'd rather have some place that has media blasting experience with our cars to do the work.
I'm also going to send my injectors out to Advanced Fuel Injection to have them tested and cleaned.
bpu699 11-16-2017 07:27 AM
Not sure the delivery guy would b willing to let me open the package and look before paying...
I paid with a business check... wasn't a MO or cashiers check...
Ken911 11-16-2017 02:25 PM
they had my cam towers less than a week. I called in advance sent a cashiers check to cover cost and shipping they were back in a few days. Excellent work.
Trackrash 11-16-2017 02:34 PM
Sounds like a good choice on bead blasting. I was at a machinist friend of mine's shop recently who showed me a set of heads someone blasted that looked awful. Might as well have used sand on them, rough and porous looking. IMO blasting needs to be done right.
KTL 11-17-2017 09:00 AM
Wow that's a lot of heavy stuff to ship to Arizona. All that work to pack them securely (make sure to pack the heavy things like they need to be bomb proof) would make me want to coordinate a road trip vacation to Arizona!
A fantastic way to ship heads is to bolt them back-to-back on a piece of wood and that wood is sized to fit "precisely" in the box. cgarr does this for all the heads he services
http://forums.pelicanparts.com/uploa...1326265962.jpg
bpu699 11-17-2017 09:35 AM
Recently got my heads back from Craig, he now packages them in separate cardboard boxes with packing material. Mine had the studs removed, maybe that effects packaging? Was very secure, well protected...
Surprisingly, shipping was way cheaper than I thought. I believe it was about $60 heavily insured, through FedEx. Cheaper than driving it to a machine shop in Chicago... and a better result.
KTL 11-17-2017 09:45 AM
Probably has encountered problems with the studs if the side of the box gets hit? I'm going to bring him my heads and some other stuff pretty soon. Just have to get it on the calendar and get approval from the CEW (Chief Executive Wifey) to take a day for a visit with Craig & his brother Denny for beers & pizza & laughs.
Trakrat 11-17-2017 10:48 AM
That's a good idea with the piece of wood used to reinforce the box.
I was planning on just reinforcing the boxes with extra cardboard and bubble wrap to keep them in place inside the box.
The only pain is shipping everything in multiple boxes and determining the insurance value on everything.
cgarr 11-17-2017 05:17 PM
The wood added to much shipping weight besides I didn’t have anymore kitchen cabinet shelves to cut up (wife is pissed) so went to double boxing I hate wood work!
mikedsilva 11-17-2017 06:03 PM
haha, that was funny :)
Trakrat 11-27-2017 11:10 AM
Finally got the case apart... Had an issue with the orange, rubber ring that was stuck on the case.
Also missed one nut that I couldn't figure out where it was... took me about 5-10 minutes of looking at every corner of the case to find it. It was covered in grime was the problem.
http://forums.pelicanparts.com/uploa...1511813389.jpg
