Harry Krause
engine oil cooler seal lube
I apologize if this has been hashed over before but I just mounted my engine oil cooler by lubing the three seals (Elring brown) with 20/50 engine oil. Now I find Dow 111 is the recomended lube. Do I need to dissassemble and try to source the 111? How critical is this?
Thanks all- Harry
HBKrause Past: 85 911 Euro Carrera Present: 73 914-6 2.7 conv |
You should be fine...
It will be fine.
seal lube
Does it leak?Oil has always been fine.
