-   -   What to use to cover this hole (http://forums.pelicanparts.com/911-engine-rebuilding-forum/975274-what-use-cover-hole.html)
bcgreen 10-25-2017 08:53 AM
The preheat hose runs through here but I don't use it presently and would like to cover it with something. I was thinking of a rubber grommet but I don't know if they even make one that large. Want to use something that I can paint if necessary and still look unobtrusive.
http://forums.pelicanparts.com/uploa...1508946779.jpg
75 911s 10-25-2017 10:50 AM
Here is what I did: For cars with the air pump, you can find the stock rubber grommet that goes in the tin hole, it looks to be a similar size. I then used an off the shelf drain plug from home depot, painted it satin, and tightened it up from below. Keeps the dust out.
http://forums.pelicanparts.com/uploa...1508953801.jpg
This is before I cleaned up the area and powedercoated the rear tin satin.
http://forums.pelicanparts.com/uploa...1508953812.jpg
