What to use to cover this hole
The preheat hose runs through here but I don't use it presently and would like to cover it with something. I was thinking of a rubber grommet but I don't know if they even make one that large. Want to use something that I can paint if necessary and still look unobtrusive.
66 Shelby Hertz Renta-Racer 68 Shelby 500KR 78 Ferrrari 308 16 Macan S 11 Speedster |
Registered Minimalist
Here is what I did: For cars with the air pump, you can find the stock rubber grommet that goes in the tin hole, it looks to be a similar size. I then used an off the shelf drain plug from home depot, painted it satin, and tightened it up from below. Keeps the dust out.
![]() This is before I cleaned up the area and powedercoated the rear tin satin.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
