This is what piston looks like from an overrev
Just wanted to share this with everyone...
The pics are Piston 1, 2 and 3.
1987 Porsche 911 Carrera Coupe
Old 11-08-2017, 04:08 PM
The bent valves are also a good indication. Judging from #1 and #2 you have couple.
Old 11-08-2017, 04:14 PM
sorry... meant to share this on the 911 Technical Forum... since there will be more eyes to see this.
If anyone knows how to move this thread... please do so.
Old 11-08-2017, 04:33 PM
safe's Avatar
A few more hits and you'll have clearance for the valves.
How high did you rev?
Magnus
Old 11-09-2017, 04:49 AM
Thats a very hard overrev,............
I would be checking the big ends of the rods and I might even replace the rod bolts.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-09-2017, 09:06 AM
probably ~ 9k rpm I would guess. misshift from 4th to 2nd.
Old 11-09-2017, 01:09 PM
yep... I'll be replacing everything with Raceware.
Old 11-09-2017, 01:10 PM
Chain fence eating turbo
That piston beat the **** out of that valve! Damn!
Old 11-09-2017, 04:00 PM
Jeff Alton's Avatar
How long did it run after the over rev?
www.turn3autosport.com
Old 11-09-2017, 08:13 PM
Couldn't have run at all. It won't build any compression.
Old 11-09-2017, 10:33 PM
ARP is better (long story behind that).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
Old 11-10-2017, 07:51 AM
It ran until I put the car in neutral as I coasted to a stop at a stop light. As soon as the car came to an idle, it died and would not start again with both oil and battery light on.
The engine would turn with the start, but other than a cough here or there, the engine never fired up again.
Old 11-10-2017, 01:33 PM
really? interesting... as I've heard horror stories from ARP failures from 10 years ago when I had a 4cyl turbo.
Old 11-10-2017, 01:34 PM
It continued to run long enough for me to go another 1/2 mile down the highway and go up hill to a stop light.
In fact, I didn't think any damage happened, as everything seemed fine for the next minute of driving.
It wasn't until I came to a stop with the gear in neutral that the engine died.
Old 11-10-2017, 01:37 PM
Reiver
Reiver's Avatar
Must be a heart rending deal when you popped the clutch on second...Stock shifter?
De Oppresso Liber
Strength and Honor 5th Legion
Old 11-10-2017, 04:11 PM
That's really odd. So, were there some cylinders that didn't have contact? Mine had much less piston damage, and it was completely dead once I pushed the clutch in and wouldn't start at all. Then again, most of the exhaust rockers broke too.
Old 11-10-2017, 06:34 PM
nope... all pistons got smacked the same.
Other than the piston head damage on the surface, I haven't found anything else that is as clear of damage.
Even the valve stem heads themselves are in fairly decent shape. Figured with a smack against the piston like that, I would have seen some damage.
I've removed the pistons and all I have left are the rods and case to take apart. Just a visual inspection of the rods doesn't show any of them bent.
Old 11-12-2017, 01:28 PM
Eva
911SauCy's Avatar
THIS is the single reason I will not let anyone drive my '78.
The consequences of a single miss-placed shift are grave...
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 11-16-2017, 07:39 AM
One form of protection you can do is to set your rev limiter lower... My motors redline is 6700. My revlimiter on the track for HPDE events is set at 6000 with the MSD.
I figure that does a couple things...
If I miss a shift from 3-4 and go 3-2, I have an added cushion. And, I have done that a couple times... No bent bits, no piston hits. I did find out later that my motor has aftermarket springs, I am sure that helps...
I would think on a missed downshift you get the same protection... you are resetting your peak rpm to 700 rpm lower...
Is that a practical solution in racing? Nope.
Does it help with HPDE where there are no trophies and it can save your motor... yep...
6700 rpm on the street... 6000rpm on the track... cheap insurance at HPDE
Bo
Old 11-16-2017, 07:56 AM
Bo
It's my understanding that your rev limiter just keeps your throttle from accelerating past redline.
There is no device that prevents you from manually shifting the gears to whatever gear you want that I'm aware of.
I would guess that you would have to have some kind of electronic controlled transmission to keep you from moving that shift lever.
Old 11-16-2017, 08:22 AM
