This is what piston looks like from an overrev
Just wanted to share this with everyone...
The pics are Piston 1, 2 and 3. ![]() ![]()
1987 Porsche 911 Carrera Coupe |
The bent valves are also a good indication. Judging from #1 and #2 you have couple.
sorry... meant to share this on the 911 Technical Forum... since there will be more eyes to see this.
If anyone knows how to move this thread... please do so.
A few more hits and you'll have clearance for the valves.
![]() How high did you rev?
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Thats a very hard overrev,............
I would be checking the big ends of the rods and I might even replace the rod bolts.
Steve Weiner Rennsport Systems Portland Oregon (503) 244-0990 porsche@rennsportsystems.com www.rennsportsystems.com |
probably ~ 9k rpm I would guess. misshift from 4th to 2nd.
yep... I'll be replacing everything with Raceware.
Chain fence eating turbo
That piston beat the **** out of that valve! Damn!
How long did it run after the over rev?
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
ARP is better (long story behind that).
It ran until I put the car in neutral as I coasted to a stop at a stop light. As soon as the car came to an idle, it died and would not start again with both oil and battery light on.
The engine would turn with the start, but other than a cough here or there, the engine never fired up again.
really? interesting... as I've heard horror stories from ARP failures from 10 years ago when I had a 4cyl turbo.
It continued to run long enough for me to go another 1/2 mile down the highway and go up hill to a stop light.
In fact, I didn't think any damage happened, as everything seemed fine for the next minute of driving. It wasn't until I came to a stop with the gear in neutral that the engine died.
Reiver
Must be a heart rending deal when you popped the clutch on second...Stock shifter?
De Oppresso Liber Strength and Honor 5th Legion |
Other than the piston head damage on the surface, I haven't found anything else that is as clear of damage. Even the valve stem heads themselves are in fairly decent shape. Figured with a smack against the piston like that, I would have seen some damage. I've removed the pistons and all I have left are the rods and case to take apart. Just a visual inspection of the rods doesn't show any of them bent.
1987 Porsche 911 Carrera Coupe Last edited by Trakrat; 11-16-2017 at 08:18 AM.. |
Eva
THIS is the single reason I will not let anyone drive my '78.
The consequences of a single miss-placed shift are grave...
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
One form of protection you can do is to set your rev limiter lower... My motors redline is 6700. My revlimiter on the track for HPDE events is set at 6000 with the MSD.
I figure that does a couple things... If I miss a shift from 3-4 and go 3-2, I have an added cushion. And, I have done that a couple times... No bent bits, no piston hits. I did find out later that my motor has aftermarket springs, I am sure that helps... I would think on a missed downshift you get the same protection... you are resetting your peak rpm to 700 rpm lower... Is that a practical solution in racing? Nope. Does it help with HPDE where there are no trophies and it can save your motor... yep... 6700 rpm on the street... 6000rpm on the track... cheap insurance at HPDE Bo |
It's my understanding that your rev limiter just keeps your throttle from accelerating past redline. There is no device that prevents you from manually shifting the gears to whatever gear you want that I'm aware of. I would guess that you would have to have some kind of electronic controlled transmission to keep you from moving that shift lever.
