1967 S Cam distributor recurving
Hi,
Following on from a previous post, I am having my Bosch distributor from a 2.4T 1973 recurved to work with 1967 S cams, matched with 90mm cylinders and 10.5:1 high comp pistons, 2.4 crank, ported cylinder heads and a Zenith carb with 34mm venturis, 145 main jets, 60 idle and 185 air jets.
I didn't mention in my earlier post that the S cams were from a 1967. Will the distributor part number 0 231 169 008 work ok with these cams and is it it still the case that the recurve should be set at 28 to 30 degrees BTDC@6000 with no vacuum attached.
Thanks in advance.
Rob.
Old 01-02-2018, 01:13 PM
Under the radar
Trackrash's Avatar
It' s my understanding that all the factory S cams up to '73 are the same.
With single plugs and that CR I would not go over 28 degrees maximum advance. I assume you are eliminating the vacuum advance from the distributor. Even so, you will be on the raged edge using pump gas with single plugs.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-02-2018, 05:32 PM
yes, you are right
A ISO/TS16949 certified OE manufacturer of Auto Parts since 2004. Producing fuel line, oil cooler, water outlet/thermostat assembly, coolant water pipes, all kinds of tube/pipes. Website & Page: www.fb.com/021auto
Old 01-02-2018, 06:06 PM
Thanks.
So should I be looking to permanently remove the vacuum advance?
I forgot to say, I'm in the UK where there's plenty of hi Octane pump gas available.
Old 01-03-2018, 01:39 AM
Under the radar
Trackrash's Avatar
Not sure why you would want or need a vacuum advance.
Gordon
Old 01-03-2018, 02:03 AM
Vacuum advance takes advantage of lean mixtures at part throttle (burn is slower), thus more ignition advance to take advantage; also increases fuel mileage.
At WOT = lower vacuum retards timing (thus no advance) from the vacuum mechanism.
If working properly, does not affect total mechanical (centrifugal) ignition advance.
Sherwood
Old 01-06-2018, 03:10 PM
