Sorry for the delay in replying. I got my ATV jack at Costco for about $80. I have seen them offered at Harbor Freight too.
Troy |
JTO - I have seen one at harbor freight but it only raised 16-inches. I'll have to see if Costco has them in my area that raise 36-inches.
Antares fatnwide |
I just purchased the ATV lift at Costco. Here are a few details on the lift;
Brand - Powerlift Hydraulics Weight capacity - 1500 lbs. Minimum height - 4.5 in. Max Height - 17.125 in. Overall length - 38 in. Overall width - 20 in. I'll be able to provide the effectiveness of this particular lift after this weekend when we drop the 930 engine. Dave 85 factory slantnose 78 RoW 911 SC (for sale) |
Thanks for the info. I havent purchased mine yet so please let us know how it works.
Good Luck on the Drop!!! |
Yes, the lift isn't what I said but more like 18". I forgot that I put 8" LVL blocks on the platform and found it worked well. I recently changed the way I drop the engine. Now, I jack the car just high enough to get the oil lines, clutch, etc detached. Then I use the ATV lift to support the engine and undo the four engine/tranny bolts. I lift the car with my jack at the tunnel with a 12"X12" piece of plywood to distribute the car's weight. Once the valence clears the FI, I roll the engine/tranny out and lower the car back down on the jack stands. I works really slick with less drama.
Troy |
| All times are GMT -8. The time now is 08:13 AM. |
