Conflicting info
Hi,
I have 1976 911 2.7l.
I've checked few sites and manuals and getting conflicting info on the head studs and valve housing torque specs.
I'm doing few things on the car and will be doing valve adjusted and since there I want to re torque the head studs and valve housing bolts.
I appreciate the input.
Thank you
1974 911 coupe 4 speed
Old 11-26-2017, 04:31 PM
You have a catch 22 going for you.
Retorquing the heads, if the magnesium is weak, you’ll pull studs and need to insert the case with a dis assembly and freshen up.
There is no short cuts because the drilling and tapping produces chips and dust
You won’t find looseness in the cam carrier to the heads.
The heads torque to twenty five ft/lb
Bruce
Old 11-26-2017, 05:12 PM
I believe the previous owner upgraded the head bolts, is there any way to confirm visually?
Thank you.
Old 11-27-2017, 03:45 AM
Difficult to see but you might be able to get a thin magnet through there to see if it still has the original steel studs, which are actually pretty good. Torque spec for the nut is indeed 25.
No physical quantity completely explains its own existence
Old 11-27-2017, 04:19 AM
Thank you.
The head studs are not the problem; the engine case threads are the real issue. The 2.7 uses steel studs which never frail.
I would NOT retorque them; if you want to know if a stud has pulled, you can VERY GENTLY see if the nuts are tight (this takes a deft touch!).
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 11-27-2017, 09:22 AM
How gently? With a torque wrench or without?
Old 11-29-2017, 02:17 PM
If the studs are pulled, the nuts will be finger loose. You need a Tem mil Allen and virtually no torque
Bruce
Old 11-29-2017, 03:19 PM
