You’re correct that we were talking forged pistons. I was just curious if the composition of the aluminum alloy relating to the cylinders was similar to that.
Thanks for the clarification. I was confused, too many threads here.
So M142 is one of those new super alloys? |
As a side note this article states that M142 is use for CAST Corvette pistons.
Amazing how metallurgy has advanced in the last few years. https://books.google.com/books?id=pG1cD2F_iJcC&pg=PA80&lpg=PA80&dq=m142+alu minum&source=bl&ots=QNE4TFdsC-&sig=EUZaJPZ-YWaIQ6wYkbMSyFxTvp0&hl=en&sa=X&ved=2ahUKEwi9nobO44 vdAhVi7YMKHWElC90Q6AEwAnoECAAQAQ#v=onepage&q=m142% 20aluminum&f=false |
Here is an article that states "Trey McFarland, the sales/marketing manager of MAHLE Motorsport in Fletcher, North Carolina, says his company is bringing a new aluminum alloy, M142, to the performance aftermarket." dated 2015. https://theshopmag.com/features/choosing-right-pistons-rings
Pistons are as important as the builder. I cringe at the sharp edges on the dome when they're dropped in without fine finishing even with tbc regardless of manufacturer.
Sent from my SM-T580 using Tapatalk |
My Hobart Gas drive welder with a Kohler K17 series 2 motor uses Mahle pistons as supplied from the factory, air cooled flat head twin with forged Mahle pistons, maybe JE will get into that market too, LOL!
The alloy used in Nickies is best suited for the 2618 alloy, but we have been working with Mahle Motorsports to provide matched combos using their proprietary alloys, as they are unable to get cylinders out of Mahle due to lack of demand and the low volumes that make it costly to support the Porsche aftermarket. We introduced last December 5 old MM part numbers sold through SSF Auto Parts and IMC, who market to shops. We're currently seeking input on which NLA kits they would like re-introduced, with obvious revisions in the design to take advantage of improvements in piston design and manufacture. I've been very happy with Mahle Motorsports and they put out a piston that is second to none, not saying that JE and CP don't make a good piston, but the Mahle parts are just that bit better (but much more expensive) |
You can have a cheap piston and expensive piston from the same company. It's all in how you order it. I just made a set of pistons for a custom build with .7/.7/2.0 rings that cost me almost $700 for one set. Just the rings. And some sets cost less than $100 for the same bore and application in a 1.0/1.2/2.0 size. You get what you pay for. |
Another olllld thread bump. @cnavarro - I ended up with your 3.6-3.9 JE setup at 12.5:1 - and I realize now that this will be a street only setup, so the 12.5 need to go. I know I can get the 11.4 mahle pistons from you guys in 2618 to match these cylinders...but I've also been looking closely at the Mahle rsr 3.6-3.8 package for 109mm case in 4032. I know you "should" be biased towards the Nickies ;) - but for a strong running street car that I'd like to actually put some miles on - what is the ideal move here? Which combo has the most up to date piston design? Cost will probably be somewhat of a wash.
Thanks! |
JE’s can be custom ordered in 4032, I’ve done so for my 2.7RS+ engine. And they do not appear to require the 2.4 head to be chamfered as the piston crown does not extend from the edge of the piston. I’ve ordered these in custom 24cc 10:1CR which after fly cut heads resulting in 66.5cc heads and 1.1 mm PtoH clearance gives 10.2:1 static compression. Should work out OK on 98 or 100 RON.
Top fuel dragster pistons are cheaper with 2 extra. I don’t buy the supply/ demand deal. We are getting screwed ( Porsche Tax).
LN like many suppliers offer off the shelf ready to go parts .. all JE off the shelf pistons are 2618 .. doesn’t mean it’s the only option out there. 2618 pistons are not known for longevity in a road engine, despite the latest skirt coating making them quieter with their wider cold clearances than 4032. Custom spec pistons are easily specified and ordered with little extra cost for those who care to research. |
| All times are GMT -8. The time now is 09:46 PM. |
