What happened to this piston?
Not my engine, but I toor down a 2.7CIS engine because of a bad leak down and found this.
I see all pistons have hit the exhaust valve, but cyl1 has taken some more beating.
What happened to that?
Old 01-02-2018, 01:19 AM
Looks like the engine already had a previous failure like a broken valve...
There are some grinding marks on the crown of the piston, I would guess a quick rebuild changing one head and smoothing the dents on the piston...
Many projects on the way...
1987 930 Road trip car (1/2 owned)
1982 DP935 future beast
1969 911T rust bucket
1966 911 Buffum college car (1/2 owned)
Old 01-02-2018, 02:37 AM
Looks like it jumped time after a tensioned collapsed, bending valves and breaking rockers.
Not enough damage for a broken valve, maybe just a chip on the face after bending
Bruce
Old 01-02-2018, 03:14 AM
The engine was running so all valves are intact, same with rockers, but similar marks in the cyl1 head.
Would a over rev make the exhaust valves hit before intakes?
But a broken valve and a quick rebuild sounds plausible
Old 01-02-2018, 03:18 PM
gearhead
Have it been rebuilt previously and had the case align bored?
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 01-02-2018, 03:34 PM
Under the radar
Trackrash's Avatar
Where was the leakage when you did the leakdown? Exhaust? Then the valves were recently bent.
It is also possible that something got down the intake like a nut or washer, who knows when. What does that cylinder wall look like?
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-02-2018, 05:16 PM
definitely had some serious hits with the valves... Wouldn't be surprised if a piece of the valve broke off and got chewed on by the piston head.
1987 Porsche 911 Carrera Coupe
Old 01-04-2018, 08:08 AM
