Slippery Slope Expert
Steam Driver's Avatar
Piston to Valve Clearance
Are the numbers given for piston to valve clearance in Wayne's book "hard and fast?" When I check #1 and #4 using that method I get numbers that are essentially the reverse of the 1.5mm Intake/2.0mm Exhaust. Mine are more like 1.75 on the Exhaust and 2.0 on the intake. j Are these acceptable?
I know his numbers on deck height are somewhat conservative relative to the factory numbers. Would the same apply here?
Oh, engine is SC with 9.8:1 Mahles. Stock cams.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.”
Old 12-31-2017, 11:03 AM
Provided you measured at the closest approach, you’ll be fine. The factory workshop manual mentions.8mm as the minimum.
-Andy
Old 12-31-2017, 03:54 PM
Thanks for your reply. I’m still mulling it over as to what to do. Still considering pulling the heads on one side and checking with clay.
Old 01-01-2018, 05:36 AM
There is a very simple way of checking the clearance between the valves and the piston.
You need a degree wheel fitted and zero’ed out to true TDC on the crankshaft. Then a simple indicator and holder. Make sure the indicator is steady and has no movement other than its measuring travel.
Fit 1 piston to the engine along with the cylinder. Fit any base shims etc you think you want to use. At this time you can cc the piston and the head chamber to calculate the engines compression.
Turn the crankshaft so it is at 20° BTDC. You will be measuring from 20° BTDC to 20° ATDC every 5 or 10°. This will depend upon how much data you require.
Now fit one head to the engine with both valves fitted but without springs and the rest of the parts. With the engine at 20° BTDC , measure each valve from its seated position on the valve seat to where it touches the piston. This is done by hand with the indicator. Make sure the travel of the indicator is aligned with the valve stems. Record the distance travels by the valve. Also make sure the valve goes into the pocket if there is one without it touching the pocket edges. Otherwise this will give you false readings.
Now move the crank to 15° BTDC or 10° if you want less data. Repeat this until you get to 20° ATDC.
Now if you have the valve lifts your cam produces from your cam supplier at these same degree positions, do some simple math to obtain the clearances. You may find its negative but its on paper and easy to calculate the amount each pocket needs to be machined. But remember your CR will change as well.
If you don’t have the valve lifts of your cam, remove the piston and rod from the engine. Re fit the head with checking springs along with the cam deck and camshaft, timed as you expect to run it. Now re fit the indicator on the back of the rocker adjuster. Make sure it is seated well and cannot move as the valve is depressed. Now repeat the same measuring positions from 20° BTDC to 20° ATDC. This will give you the valve lift numbers that you need to subtract from the valve seat to piston numbers.
This will give you the P/V clearances and this way, if you are fitting new pistons that need the pockets machined but do not know by how much, this method will give you any interference on paper only.
If you wish to side step this last part, you can send us the cams you wish to use and the cam timing you expect to run and we can run the cams and supply you with the lift numbers at that timed position.
Old 01-03-2018, 01:18 PM
