VarioRam value
A friend of mine has a complete 1997 VarioRam engine with 41k miles on it.
Can you guys give me an idea of what that engine is worth?
Old 01-25-2018, 01:49 PM
The varioram piece doesn't really add much to the value, still, I'd say 15-20K for the package. It's higher because it's one of the newest air cooled motors you can buy, and there are those out there that like varioram and hydraulic lifters.
Old 01-25-2018, 01:59 PM
Apologies. Im calling it a VarioRam because I just don't know any better.
Its a 1997 993 engine with 41k miles. Includes the engine and everything that goes with it. Harness, ECU, exhaust, etc.
No transmission though.
Still $15-20k?
Old 01-25-2018, 02:52 PM
Still $15-20k?
You're 100% right, it's a varioram 3.6. What I was getting at was that Varioram is the final iteration of adjustable intake runner intake system on a 911 motor. The reason why I said that it doesn't add (or subtract) value to the motor is because these motors are going in hotrods and other builds where more power can be obtained with a different intake system than varioram could provide.
But yeah, that motor is worth 15-20K. Probably more in the middle of those two figures.
Old 01-25-2018, 06:14 PM
Perfect thanks.
Old 01-25-2018, 06:18 PM
I paid $16,000 for mine with 39k miles 2 years ago.
FWIW
81 SC 3.8 Conversion
2017 Macan S
INSTAGRAM @tail_spinz
Old 01-25-2018, 08:16 PM
JmuRiz's Avatar
Originally Posted by Catorce View Post
... and other builds where more power can be obtained with a different intake system than varioram could provide.
Is this true for the mid-range, or just the top-end? I would think the varioram intake would help with fattening up the middle compared to a static intake length.
I have no experience on these engines with variable intake length, but in my old 4.2l S6 engine making the variable intake work correctly greatly helped the area under the curve in the mid-range (buttdyno tested).
'73 2.0 914 (2.8 /6 conversion in progress)
'64 356SC
'65 Ducati Falcon 80
‘19 Audi SQ5
Old 01-26-2018, 07:00 AM
^ If Vram was the ****, then you wouldn't see things like ITBs, fuel injection with Carrera 3.2 intakes, and all kinds of other variations.
As an example, the Vram 3.6 makes ~290 hp, while the same motor with Singer bits in 3.8 makes 375+. Lots of low hanging fruit in the intake.....
Old 01-26-2018, 08:56 AM
Tags
993 , engine , varioram
