-   -   Intermediate shaft - adding second bearing in early Mg case (http://forums.pelicanparts.com/911-engine-rebuilding-forum/987579-intermediate-shaft-adding-second-bearing-early-mg-case.html)
horizontallyopp 02-13-2018 04:15 PM
For my 69 magnesium case, once the case has been reamed for the second intermediate shaft bearing, does it require a different intermediate shaft? Or is the ID of the bearing the same as the OD of the existing shaft? I searched and didn't find a definitive answer.
stownsen914 02-16-2018 08:34 PM
Since you started with a mag case, the intermediate shaft should be the same one that the later mag cases with the second bearing used.
