Intermediate shaft - adding second bearing in early Mg case
For my 69 magnesium case, once the case has been reamed for the second intermediate shaft bearing, does it require a different intermediate shaft? Or is the ID of the bearing the same as the OD of the existing shaft? I searched and didn't find a definitive answer.
Keith - Calgary
1969 912R (911 engine) - Blutorange
Old 02-13-2018, 04:15 PM
It's a 914 ...
stownsen914's Avatar
Since you started with a mag case, the intermediate shaft should be the same one that the later mag cases with the second bearing used.
Old 02-16-2018, 08:34 PM
