964 valve spring check?
What is the values for checking valve spring on the 964?
I can only find it for up to -89 (compressed lengt vs force)
Old 03-26-2018, 04:30 AM
I believe the 964 spring prescribed to the same forces as the earlier springs. When the heads are off I recommend replacing them anyway. Dougherty cams or Cgarr have a great set available now that won't break the bank (compared to Aasco $$$$).
No physical quantity completely explains its own existence
Old 03-26-2018, 07:27 AM
safe's Avatar
The springs are normally OK, but the retainers are known to crack (if you spend time above 6500) with catastrophic results. So those should be replaced.
Magnus
Old 03-27-2018, 02:17 AM
