-   -   Need Help Identifying Cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/992395-need-help-identifying-cylinders.html)
grotvik 04-02-2018 07:29 AM
https://www.ebay.com/itm/NOS-Mahle-pistons-and-liners-set-for-Porsche-2-4-911S-1972-1973-91110394401/323183007374?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2055119.m1438.l2649
The part number on this P/C set indicates the cylinders should be Nikasil. They do not look like nikasil cylinders to me (but I'm not an expert). I contacted the seller but he was unsure if they are nikasil and stated the part number indicated they were.
Thoughts?
Thanks,
Greg
MBruns 04-02-2018 07:43 AM
cyls
Those are birel, which is an iron liner that is cast with the aluminum fins, good cyls just an expensive process.
Mike Bruns
