Need Help Identifying Cylinders
The part number on this P/C set indicates the cylinders should be Nikasil. They do not look like nikasil cylinders to me (but I'm not an expert). I contacted the seller but he was unsure if they are nikasil and stated the part number indicated they were. Thoughts? Thanks, Greg |
cyls
Those are birel, which is an iron liner that is cast with the aluminum fins, good cyls just an expensive process.
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago. |
