Shift fork wear marks
Hi, hopefully someone can help me identify what would cause this wear mark on my shift fork. Car is a 73t with a 2.4 engine and a 911/01 transmition.
Mike
Old 04-24-2018, 06:47 AM
I assume you're talking about the mark out near the bell housing? Looks like something let go on a previous clutch and got jammed between the PP cover and the fork. That similar mark on the bell looks to be almost in line with the mark on the fork?
Or what ever let go was still attached to the clutch and rubbing on the fork and bell housing as it went around.
Old 04-28-2018, 04:36 PM
pete3799's Avatar
Clutch pedal depressed too far. Adjust your pedal stop on the floorboard.
Pete
79 911SC RoW
Old 04-28-2018, 04:59 PM
Ah yes, that would do it. Must make a nice racket.
Old 04-28-2018, 05:44 PM
Under the radar
Trackrash's Avatar
Why would a '73 have that transmission?
At any rate, my shift fork looked like that. Why? Because when the ball joint pivot breaks off the release arm will rub on the PP. I'm sure this has happened in the past on your trans.
Gordon
'71 911 Coupe 3,0L outlawed
Old 04-28-2018, 10:10 PM
Hi guys sorry I missed the reply’s but no sorry boosted79 I don’t think anything let go I replaced the clutch,throw out bearing and fly wheel a thousand or so miles a go and that mark was not there and had no issues or noise in the mean time.
Trackrash the op must haves changed the transmission to a 911-01 for some reason in the past but the replacement works fine.
Thanks guys I will take a look at the pedal adjustment.
Mike
Old 05-16-2018, 05:06 PM
gearhead
My 75 has one as well as a 2.2e engine. People did strange things 20 years ago to keep them on the road.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-16-2018, 08:01 PM
Hi Matt, the shift pattern is a little different but once you get used to it it’s
Actually nice.
Old 05-17-2018, 03:24 AM
