Gumba44
Gumba 44
'75 911S w/sic. Have a consistent starting the motor problem when the motor is cold. Have done the pop offs and checked the injection, fuel lines, filter, timing et al. Any ideas?
Old 04-30-2018, 06:41 PM
BURN-BROS's Avatar
problem only when cold? How about 1 hr after engine is off? If so check fuel accumulator.
If not, check WUR cold pressure.
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 05-01-2018, 07:37 AM
Gumba44
Tks Aaron. I’m constantly adjusting the throttle lever to get the right mix resulting in long waits between cranking & starting.
Pls educate the uneducated here. How does the WUR cold pressure valve work? Again, tks for taking the time
Old 05-01-2018, 08:49 AM
BURN-BROS's Avatar
Hell if I know....I'm an MFI guy
I can tell you that system pressures dictate everything . If they are not within specs then there is an issue. Some people adjust the WUR to alter the system pressures. but I believe they are working around the real problem...like the fuel distributor may need service or the WUR is requiring recalibration...or both.
And then there are air leaks..that system has a great deal of potential leaks!
Burnham Performance
Old 05-01-2018, 09:11 AM
