oversize main bearings cost !!! :(
Hi Everyone,
anyone here had experienced the need for oversize main bearings ??
I'm in the process of rebuild my engine (911sc) I sent the case to the machine shop for inspection and the case line bore is 0.010 (from previous rebuild) number 8 bearing is standard, crank is std/std
the issue is the price tag on these oversize main bearings is just ridiculous how expensive these are, any alternative options ? probably not, but still cannot belive and digest the cost $$$$$$$
Jose
Old 05-07-2018, 10:58 PM
Ollies930's Avatar
Better get the bearings quickly. I was in the same boat with my engine and found out that there were only 14 sets left in stock in Germany about 6 months ago. Doubtful that they will make any more ever again. And the nose bearing comes with it as .010" O.S. so you have to buy a STD sized one, if yours is no good.
Old 05-08-2018, 09:42 AM
the used bearings are in good shape, I'm wondering if these can be sent for re-coat ?
anyone here have done something similar ?
I have to mentions that case was splitted because the engine was out already the issue with the engine was a cylinder head /valve seat
Thx
Old 05-08-2018, 12:14 PM
Ollies930's Avatar
Read here: Is 4 to 5 thou too much main bearing clearance
Old 05-08-2018, 12:23 PM
bearings
Send them to HM Elliot Inc, Mooresville NC 704 663 8226
you will need to check the after coating clearance it will reduce what you have by .0008 +/-
Mike Bruns
The two most useless things to a driver are the braking distance behind you and nine-tenths of a second ago.
Old 05-08-2018, 12:24 PM
Thanks a lot !!
I will send them to HM Elliot
Old 05-08-2018, 01:27 PM
Probably time to look for another case
If a valve was the problem, why did you split the case.
You did a line bore when the current way to go is milling center line and linebore to standard.
Bruce
Old 05-08-2018, 01:42 PM
the case was leaking oil, and the line bore job was done before on a previous re-build not me
Old 05-09-2018, 09:51 AM
