-   -   3.6 Cam Timing with Stock Tensioners? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/995468-3-6-cam-timing-stock-tensioners.html)
drola 05-03-2018 06:51 AM
What is the consensus?
I have seen some people who say to use a steering wheel puller, stomski tool, or other such device to tension the chains.
I have also seen some who say to use the stock tensioners to tension the chains for timing.
I am ready to time my cams and don't have the specific tool. Should i wait to source one or are the stock tensioners sufficient?
Flat6pac 05-03-2018 08:10 AM
I ve always used the stock tensioners in good condition
There is a variable in the numeric settings, the chains are tight, but not distorted, and as the chains heat they expand.
Everything is variable
Bruce
Luckyboy 05-21-2018 07:44 PM
That’s the purpose of the hydraulic tensioners, to keep that variable on check, cold or hot.
Pedro.
smokintr6 05-23-2018 04:17 AM
I used the stock tensioner as well.
