drola's Avatar
3.6 Cam Timing with Stock Tensioners?
What is the consensus?
I have seen some people who say to use a steering wheel puller, stomski tool, or other such device to tension the chains.
I have also seen some who say to use the stock tensioners to tension the chains for timing.
I am ready to time my cams and don't have the specific tool. Should i wait to source one or are the stock tensioners sufficient?
IG @Drola964
1973 BMW 2002
1990 964 C2
2007 GT3
2014 Ram 2500 Cummins
Old 05-03-2018, 06:51 AM
I ve always used the stock tensioners in good condition
There is a variable in the numeric settings, the chains are tight, but not distorted, and as the chains heat they expand.
Everything is variable
Bruce
Old 05-03-2018, 08:10 AM
Banned
That’s the purpose of the hydraulic tensioners, to keep that variable on check, cold or hot.
Pedro.
Old 05-21-2018, 07:44 PM
smokintr6's Avatar
Send a message via AIM to smokintr6
I used the stock tensioner as well.
Old 05-23-2018, 04:17 AM
