CIS injector hole plugs, carbed engine
What is the best method to plug the injector holes in CIS heads ? (not MFI)
The engine is carbed. Anyone make a suitable remedy ? TIA Rory |
There are insulators to encompass the notch
I would contact PMO for a set. Bruce |
Thank You You've brought something to my attention. The heads I'm working with have a hole that extends from the top surface of the head directly into the intake port aimed at the valve. It is a ~14mm hole, not a notch. The hole is smooth, not threaded. |
On the 2.4 CIS heads, you can run a tap into the hole and then plug them just like you do with the MFI heads.
Tom hit it, the 73 CIS heads had a pressed in aluminum sleeve where the MFI injectors went.
once removed, there is no threads. That was an only year application. Bruce |
| All times are GMT -8. The time now is 05:03 AM. |
