-   -   This sucks new WEB cam has a big pit starting (http://forums.pelicanparts.com/911-engine-rebuilding-forum/995578-sucks-new-web-cam-has-big-pit-starting.html)
Cairo94507 05-08-2018 04:58 AM
Wow, Mark. Very sorry to see that. I hope Web can fix that problem ASAP so you can get it back together and in the car to get back to enjoying it.
Best of luck,
Michael
stownsen914 05-11-2018 05:08 AM
Wow, this sucks. Sorry to hear it. I've heard that welded up cams can fail. I've been lucky with an older set I have in my track motor, but maybe this type of failure is what they mean ...
Mark Henry 05-11-2018 06:57 AM
I'm going to pull them over the weekend and send them to web. I think it's only one but I'll get them to inspect both.
I also just bought the tool (valve grinder attachment) to surface my rocker pads, so I'll check and/or rebush and make sure the pads are square.
Mark Henry 06-21-2018 06:53 PM
Got my cams back from web. :)
They hard welded the bad lobe and light regrind to make sure all's perfect, polished the journals and coated them.
Like new again.
Now to find some time to get them installed and get the engine back in the 914.http://forums.pelicanparts.com/uploa...1529632353.jpg
rwest 06-22-2018 02:49 AM
Glad you got it sorted Mark,
Quick question about the black coating on the lobes, do you need to clean it off before install or does it wear off harmlessly?
175K911 06-22-2018 03:53 AM
Like new again.
Did they offer any thoughts on possible causes?
