Shift fork wear marks
Hi, hopefully someone can help me identify what would cause this wear mark on my shift fork. Car is a 73t with a 2.4 engine and a 911/01 transmition.
Thanks Mike
I assume you're talking about the mark out near the bell housing? Looks like something let go on a previous clutch and got jammed between the PP cover and the fork. That similar mark on the bell looks to be almost in line with the mark on the fork?
Or what ever let go was still attached to the clutch and rubbing on the fork and bell housing as it went around. Last edited by boosted79; 04-28-2018 at 05:02 PM.. |
Clutch pedal depressed too far. Adjust your pedal stop on the floorboard.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Ah yes, that would do it. Must make a nice racket.
Under the radar
Why would a '73 have that transmission?
At any rate, my shift fork looked like that. Why? Because when the ball joint pivot breaks off the release arm will rub on the PP. I'm sure this has happened in the past on your trans.
Hi guys sorry I missed the reply’s but no sorry boosted79 I don’t think anything let go I replaced the clutch,throw out bearing and fly wheel a thousand or so miles a go and that mark was not there and had no issues or noise in the mean time.
Trackrash the op must haves changed the transmission to a 911-01 for some reason in the past but the replacement works fine. Thanks guys I will take a look at the pedal adjustment. Thanks Mike |
gearhead
My 75 has one as well as a 2.2e engine. People did strange things 20 years ago to keep them on the road.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Hi Matt, the shift pattern is a little different but once you get used to it it’s
Actually nice. |
