View Single Post
Matt Monson Matt Monson is online now
gearhead
Originally Posted by jlex View Post
First thing is to drain all that stale gas. Do NOT try to start it before introducing fresh gas as you'll move crap all through the system. Install a new filter. I'd drain the tank, then take off the fuel sender. Peer into the tank with a flashlight & inspect the sides with your finger. If you see rust, you'll need to flush the tank or even have it blasted or chemically cleaned. On my '88 which sat with bad fuel for about 10 years, I had to replace the tank as it was too far gone along with the injectors. You will no doubt want to examine the fuel lines, then move on to replacing plugs. Fresh oil & filter, and new battery then see if it goes. Good luck.
Definitely don't want to send any of that crud into the fuel distributor, though it will probably need to be cleaned and/or rebuilt anyway.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 05-02-2017, 06:37 PM
