Series 1 diff questions
Hello
I am looking for info regarding the series 1 and series 3 (e46 gen.) Its basically impossible to find unless you have both units side by side to compare. I wanted to check the following : - half shaft PCD, are the bolt patterns the same ? - width between the two half shaft flanges, are the widths of the casing the same ? - the front mounting points, on these ears are the mounting points the same width apart ? Thanks |
| All times are GMT -8. The time now is 08:34 PM. |
