Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 1 Series
Series 1 diff questions
Hello
I am looking for info regarding the series 1 and series 3 (e46 gen.)
Its basically impossible to find unless you have both units side by side to compare.
I wanted to check the following :
- half shaft PCD, are the bolt patterns the same ?
- width between the two half shaft flanges, are the widths of the casing the same ?
- the front mounting points, on these ears are the mounting points the same width apart ?
Old 11-15-2019, 12:59 AM
