Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
E46 fuel pump
E46 318ic - is anyone able to advise me why the flexible hose that connects directly to the fuel pump (inside the tank) burst and so did the replacement?
Old 06-28-2020, 02:01 PM
Not quite sure how the format of this site works but thanks to Nick at Pelican Parts for your reply (which I see on my iphone but not here for some reason).
For info to others, you advise - 'over pressure, heat or damage to the hose'
What I don't understand is how the same pump that's worked for years can suddenly increase pumping pressure. Is this possible? If so I'll replace it, or is there a blockage that's backing it up maybe?
When I replaced the hose it I disconnected the flow line from the filter to the rail, lots of fuel pumped out. Reconnected and with fuel to the rail it ran for maybe 5-7 seconds then the pipe burst again.
Could there be a blockage on the return line and would this cause the problem?
Any further thoughts or has the pump gone bad?
Old 07-03-2020, 10:25 PM
Thanks to Nick at Pelican who sent a reply which doesn't appear here for some reason.
Not quite sure how this forum works yet.
Nick you advise - over-pressure, heat or damage to the hose.
I guess its definitely over pressure to burst the hose but is it possible for the existing pump to get 'stronger'?
i fitted a replacement hose, disconnected the flow line from the filter to the rail - lots of fuel pumped through. Reconnected to get fuel to the rail and the car ran for maybe 5-7 seconds then the replacement pipe burst.
Would a blockage on the return line cause this or has the pump gone bad?
Old 07-03-2020, 10:32 PM
