-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   alarm & key memory information needed (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/108355-alarm-key-memory-information-needed.html)
Wasemiller 04-28-2003 08:58 AM
Ok, so I bought a 323i two days ago & for some reason the alarm doesn't arm. I have the alarm - I know that much. No flashing light, no chirp, no nothing.
Also, I know that there is a way to program this car to the person who's driving using the keys. There is absolutely no information in my owners manual or the VHS tape I watched, so does anyone on here know how to do this or do I have to take it to the dealership and have it done?
Some info please!!
Jared at Pelican Parts 04-28-2003 03:03 PM
What year is your car?
Javier at Pelican Parts 04-29-2003 08:13 AM
Yea, need to know he year. if it is a new E46 this car does not come with the alarm unless it is installed by the dealer at cust request or they added it prior to sale. Although the keys do have the control buttons for the keyless entry the module must be added to activate the sysytem. As for programiming the keyes, this has to be done at the dealer. Take it to the service department they will go over a list of the things that can and can'nt be done.
Wasemiller 04-29-2003 08:34 AM
It is an E46: 1999 sedan.
The car has the motion sensor and everything inside... is there a way to tell if the alarm has been disabled or if it is actually not installed?!
Javier at Pelican Parts 04-29-2003 09:36 AM
The motion sensor is part of the alarm system. The only real way to tell if the sysytem has been installed is to take it the dealer and ask. Or you could call and ask were they ususally place the module and then look to see if you have it. By the way when you press the buttoms on your key head does anything other than keyless entry work? ie. flashing lights, horn beep.?
Wasemiller 04-29-2003 03:05 PM
Nothing else happens only the doors lock and unlock - that's it.
Javier at Pelican Parts 04-29-2003 03:35 PM
I tend to beleive you do not have the alarm system installed, therefore you need to get one.
Jared at Pelican Parts 04-29-2003 03:41 PM
Im thinking the same as javier, that there is no alarm installed.
Wasemiller 04-30-2003 08:25 AM
so how much do they charge for activating the system? Any idea? The tabs in my trunk say that it's prewired for all the options but from what you all say, they aren't on. I'm taking it in next week, so I guess I'll find out then.
thanks =)
Tenille
Javier at Pelican Parts 04-30-2003 08:31 AM
The alalrm sysytem runs about 325.00. I think most dealers charge about 1.5hrs labor. depends on the dealer.
Wasemiller 05-01-2003 05:32 PM
that's just flippin crazy.
they can keep the damn alarm.
Jared at Pelican Parts 05-02-2003 12:17 PM
My attitude about alarms has always been, ..... Whats the point? If a thief wants your car, he's going to get it regardless. I have always rigged every car I own with a fuel and ignition kill switch that disables operation of the systems. It's not that hard to do.
oc330cic 05-05-2003 06:51 PM
Kill Switch Kits
So Jared, I presume then that Pelican offers both fuel and ignition kill switch kits? How hard are they to install? I've been thinking that a kill switch would be a good addition.
Jared at Pelican Parts 05-06-2003 08:58 AM
At this time, Pelican does not offer a kill switch kit. I rigged them all up myself. If you email me, i can go over hopw to rig something up. Eventually i want to rig up a remote controlled unit that would automatically disable the fuel pump and coil.
notoriousM3 05-14-2003 04:29 PM
Sad but true you guys are right on about the 325 dollars for the alarm. My wifes 40 grand 530i comes with an alarm. But my 54 grand M3 did not! Boy was I pissed when i found that out. And to make matters worse they wanted and additional 350 dollars to install it. I figured with over 50 grand invested why not? But had I known this when I ordered the car I'd have negotiated the alarm into the deal. I was told the alarm and built in garage door opener are standard on 5 series and optional on 3 series regardless of vehicle cost. Im sure if someone wanted to steal my vehicle he could easily get around the alarm system but my insurance company does offer a small discount for having it. I'm also told that "lojak" is the anti-theft system to buy. :(
Jared at Pelican Parts 05-15-2003 03:31 PM
Would you liek a schematic on how to rig up a kill switch?
notoriousM3 05-15-2003 06:53 PM
sure if its not too complicated...i don't want to mess around with the wiring of a M3..
Salvator 05-22-2003 02:19 PM
Here is a link to all of the key options... They have to be programmed by the dealer, and if you are not the original owner or did not buy the car from that dealer, they will probably charge you .5 hour to do the work. BTW, read the stuff about setting up your car so that it "appears" to have an alarm... flashing clown nose, beeps, etc. I have that on my car, works great. As stated earlier, a real thief will get your car no matter what, flashing lights might deter amateurs...
http://www.bmwnation.com/home.html
Go to the Tech area, Tech Glossary, Car and Key configuration options...
notoriousM3 05-23-2003 09:09 PM
thanks for the link to bmw nation :)
Jared at Pelican Parts 05-27-2003 09:41 AM
notorious,
if you give me a call, i'll go over what ou need to do in order to rig up a kill switch.
1-888-280-7799 ex. 259
notoriousM3 05-27-2003 05:02 PM
ok mate i'll give you a call sometime this week...:)
Wasemiller 05-29-2003 09:19 AM
ok, I went to the link given & it says:
"The "Clown Nose" flashes after you purchase, install and activate your BMW alarm. Did you know that you can have the Nose programmed to flash, and the amber lights blink off/on when you open/close the doors even though the alarm is NOT installed? Here's how:
1) Have your dealer hook up the shop computer to the car.
2) Go to the "Anit-Theft" activation section.
3) Activate the alarm, but uncheck the "DWA" option.
This was tested by at least a dozen people so far, who swear that it works. The shop work order the job was written as: "Program car memory to visual acknowledge when locking/unlocking"
>> question... Do I need to ask the dealer to do this?
notoriousM3 05-29-2003 11:36 AM
I do believe you need the dealer to program the keys for this function. I went to the web site and read it too. Thats the way I understood it to be :D
Salvator 05-30-2003 06:57 AM
Yes, this is a dealer-involved activity... They will probably charge you 30 or 40 bucks for the privilege, (so have all your programming ducks in a row so you can have them all done at once) but its still cheaper than buying the actual alarm system... I have this setup on my car and it works great... Alarm system appearance without the hassles (false alarms) or expense...
