Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Wasemiller's Avatar
Question alarm & key memory information needed
Ok, so I bought a 323i two days ago & for some reason the alarm doesn't arm. I have the alarm - I know that much. No flashing light, no chirp, no nothing.
Also, I know that there is a way to program this car to the person who's driving using the keys. There is absolutely no information in my owners manual or the VHS tape I watched, so does anyone on here know how to do this or do I have to take it to the dealership and have it done?
Some info please!!
Old 04-28-2003, 08:58 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
What year is your car?
Old 04-28-2003, 03:03 PM
Senior Advisor
Javier at Pelican Parts's Avatar
Yea, need to know he year. if it is a new E46 this car does not come with the alarm unless it is installed by the dealer at cust request or they added it prior to sale. Although the keys do have the control buttons for the keyless entry the module must be added to activate the sysytem. As for programiming the keyes, this has to be done at the dealer. Take it to the service department they will go over a list of the things that can and can'nt be done.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 04-29-2003, 08:13 AM
Wasemiller's Avatar
It is an E46: 1999 sedan.
The car has the motion sensor and everything inside... is there a way to tell if the alarm has been disabled or if it is actually not installed?!
Old 04-29-2003, 08:34 AM
Senior Advisor
The motion sensor is part of the alarm system. The only real way to tell if the sysytem has been installed is to take it the dealer and ask. Or you could call and ask were they ususally place the module and then look to see if you have it. By the way when you press the buttoms on your key head does anything other than keyless entry work? ie. flashing lights, horn beep.?
Old 04-29-2003, 09:36 AM
Wasemiller's Avatar
Unhappy
Nothing else happens only the doors lock and unlock - that's it.
Old 04-29-2003, 03:05 PM
Senior Advisor
I tend to beleive you do not have the alarm system installed, therefore you need to get one.
Old 04-29-2003, 03:35 PM
Im thinking the same as javier, that there is no alarm installed.
Old 04-29-2003, 03:41 PM
Wasemiller's Avatar
so how much do they charge for activating the system? Any idea? The tabs in my trunk say that it's prewired for all the options but from what you all say, they aren't on. I'm taking it in next week, so I guess I'll find out then.
thanks =)
Tenille
Old 04-30-2003, 08:25 AM
Senior Advisor
The alalrm sysytem runs about 325.00. I think most dealers charge about 1.5hrs labor. depends on the dealer.
Old 04-30-2003, 08:31 AM
Wasemiller's Avatar
that's just flippin crazy.
they can keep the damn alarm.
Old 05-01-2003, 05:32 PM
My attitude about alarms has always been, ..... Whats the point? If a thief wants your car, he's going to get it regardless. I have always rigged every car I own with a fuel and ignition kill switch that disables operation of the systems. It's not that hard to do.
Old 05-02-2003, 12:17 PM
Kill Switch Kits
So Jared, I presume then that Pelican offers both fuel and ignition kill switch kits? How hard are they to install? I've been thinking that a kill switch would be a good addition.
2002 330 Convertible
Old 05-05-2003, 06:51 PM
At this time, Pelican does not offer a kill switch kit. I rigged them all up myself. If you email me, i can go over hopw to rig something up. Eventually i want to rig up a remote controlled unit that would automatically disable the fuel pump and coil.
Old 05-06-2003, 08:58 AM
notoriousM3's Avatar
Send a message via ICQ to notoriousM3
Sad but true you guys are right on about the 325 dollars for the alarm. My wifes 40 grand 530i comes with an alarm. But my 54 grand M3 did not! Boy was I pissed when i found that out. And to make matters worse they wanted and additional 350 dollars to install it. I figured with over 50 grand invested why not? But had I known this when I ordered the car I'd have negotiated the alarm into the deal. I was told the alarm and built in garage door opener are standard on 5 series and optional on 3 series regardless of vehicle cost. Im sure if someone wanted to steal my vehicle he could easily get around the alarm system but my insurance company does offer a small discount for having it. I'm also told that "lojak" is the anti-theft system to buy.
Old 05-14-2003, 04:29 PM
Would you liek a schematic on how to rig up a kill switch?
Old 05-15-2003, 03:31 PM
sure if its not too complicated...i don't want to mess around with the wiring of a M3..
Old 05-15-2003, 06:53 PM
Here is a link to all of the key options... They have to be programmed by the dealer, and if you are not the original owner or did not buy the car from that dealer, they will probably charge you .5 hour to do the work. BTW, read the stuff about setting up your car so that it "appears" to have an alarm... flashing clown nose, beeps, etc. I have that on my car, works great. As stated earlier, a real thief will get your car no matter what, flashing lights might deter amateurs...
http://www.bmwnation.com/home.html
Go to the Tech area, Tech Glossary, Car and Key configuration options...
Old 05-22-2003, 02:19 PM
M Logo
thanks for the link to bmw nation
Old 05-23-2003, 09:09 PM
notorious,
if you give me a call, i'll go over what ou need to do in order to rig up a kill switch.
1-888-280-7799 ex. 259
Old 05-27-2003, 09:41 AM
