-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   help with center console disassembly on 323i (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/156970-help-center-console-disassembly-323i.html)
haze 04-05-2004 09:54 AM
Hi
can anyone give me directions for disassembling the center console on a 2000 323i automatic? the PRNDL indicator in my friend's car is misaligned and i need to get at it so i can convince it to properly indicate which gear is selected.
thanks
-Bryan Hays
alpine323ia 04-07-2004 04:29 PM
Bryan,
If you are refering to the automatic stick shift counsel, slide a cedit card in between the flat plastic boot and the frame of the center cover counsel and it will pop it easy. Using a plastic card will help prevent any damage around the plastic. This will give you access to the shift stick underneath.
Fitz
BMWCowboy 04-14-2004 07:05 PM
The only thing thats going to convince it is a brand new one :(
BMW===Bring Money With
And alpine is right just pull off your shift knob>>quick hard pull
and pull up the whole trans shift assy>>its a cover peice that unplugs.
alpine323ia 04-15-2004 11:35 AM
I do not even look at the shift gear but instead at the gauge cluster which tells you what gear your in anway at the bottom right corner.
