Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Send a message via AIM to haze
help with center console disassembly on 323i
Hi
can anyone give me directions for disassembling the center console on a 2000 323i automatic? the PRNDL indicator in my friend's car is misaligned and i need to get at it so i can convince it to properly indicate which gear is selected.
thanks
-Bryan Hays
Old 04-05-2004, 09:54 AM
Bryan,
If you are refering to the automatic stick shift counsel, slide a cedit card in between the flat plastic boot and the frame of the center cover counsel and it will pop it easy. Using a plastic card will help prevent any damage around the plastic. This will give you access to the shift stick underneath.
Fitz
Old 04-07-2004, 04:29 PM
The only thing thats going to convince it is a brand new one
BMW===Bring Money With
And alpine is right just pull off your shift knob>>quick hard pull
and pull up the whole trans shift assy>>its a cover peice that unplugs.
Old 04-14-2004, 07:05 PM
I do not even look at the shift gear but instead at the gauge cluster which tells you what gear your in anway at the bottom right corner.
Old 04-15-2004, 11:35 AM
