Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
I am so screwed, HELP my car died
My car has been stolling once in a while out of nowhere. It started about a year ago, and finaly it died for good.
Last week it stoled on a red light, and I can't drive it since then. [U]The engine is running though, but when I push the gas pedal it goes up to 2000 RPM and stoles again. At the very beginning I was able to drive on realy low RPM's for few feet, now I can't even move an inch. The check engine, EML and DSC lights are ON.
I'm thinking of:
- vacuum leak
- resetting
- oxygen sensor
- camshaft sensor
- throttle body
- fuel pump
Please give me some advices.
For all Los Angeles members; do you know a decent place to go and fix it, without paying an outragous amount of money.
You can't live in LA and not have a car.
Thanks.
Old 11-21-2004, 02:16 PM
my advice is to hook a scanner to your obd2 port and see what codes it will read and then look up what these codes mean on the internet there is a website that translates or explains the codes www.my330i.com . u can buy a scner for about 100 dollars or u can take u r car to a delaer and let them diagnose the problem, they charged me 93$ in NC.
i once had the dsc light come after replacing a battery but hen turned off by itself after a month or so( don't know why) but i didnt have any running probs or symptoms u described
Old 11-21-2004, 09:52 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I agree, run the codes...
Old 11-23-2004, 01:05 PM
The Chris's Avatar
I'm no bmw expert, but it sounds exactly like what would happen if the MAF sensor failed.
2008 BMW M3 | 6spd | Dinan catback
Old 12-04-2004, 12:17 PM
BMW Roundel
Usually makes it ALOT EASIER to HELP if WE knew what kind of car this is????????......sounds like cam/crank sensor but who knows with the info given?????
Old 12-26-2004, 08:30 AM
