Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
2000 323i Brakes
My girlfriends brake sensor light came on the other day about 2 months after I changed her pads (on all four spots) and changed pad wear sensors. I poked around and noticed that the rear sensor wire had been rubbing the inside of the rear wheel and it wore through. I replaced it yesterday and the light is still on. Any other suggestions?
Old 02-08-2005, 06:16 AM
Jeron's Avatar
The light will go off by itself.
From memory, I believe you can simply put the key in the iginition and turn it to on but no need to start it. It will go off in a few minutes.
Or you can just drive it and it will go off in a short while.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 02-08-2005, 08:13 AM
