Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
KNS KNS is online now
Differential Fluid Change
I am going to do a Diff. fluid change (tranny too) on my '04 325i. Do the drain plugs on the differential have washers on them?
Thanks....
Kurt
Old 05-10-2006, 09:15 PM
Yes they do, they can usualy be re-used.
Old 05-11-2006, 06:35 PM
Jeron's Avatar
I can't remember if the E46 has clearance issues getting to the drain plug like the E36. If it does not just any hex socket will work. I think it is 14mm but I'm not sure.
Pull the fill plug first.
1 to make sure you can get fluid back in
2 to check level
3 it lets air in so the fluid drains without splattering
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 05-11-2006, 10:49 PM
Thanks guys. I checked for access and it's okay. It is a 14mm too.
Kurt
Old 05-13-2006, 08:30 AM
