| Registered Join Date: Nov 2007
				ABS Fault Codes
			Hello all, I have a 1996 328i with abs fault codes 14, 17, 177. I have replaced both abs relays with no luck. Checked all fuses with no luck. Does someone have a chart showing the meaning of the fault codes? Thanks, John   | ||
|  11-24-2007, 04:47 PM |
| Registered Join Date: Mar 2007 Location: Florida
				ABS light flashing rapidly
			If you get any information on your fault codes let me know.  My 2002 330CI just began flashing the ABS light rapidly when the ignition is on.  Funny my service book says it should stay on constantly, but it doesn't mention a rapid flash. Did you get your fault codes from a code reader? Which one?? | ||
|  11-29-2007, 05:04 PM |
