What?
Diagnostic codes, p0174,p0171,p1620
Hey guys, my wifes 01 330i is running just fine, however; it through up the following OBD 2 codes.
P0171 System too Lean (Bank 1) <--- I understand this. I think. P0174 System too Lean (Bank 2) <-- and this. P1620 MAP Cooling Control Circuit Signal High <-- but what is this? Is it related to the others? Thanks
________________________________________ Eric Hahl 85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD) 2015 981 Cayman S (Sold) 23 Outback Wilderness & 23 BMW R1250GS |
Lean in both banks; first thing to check is for cracked or leaking intake tubing.
That engine has a electrically controlled thermostat. Maybe the P1620 is refering to that system.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
What?
Thanks Jeron,
I found a vacuum leak on the air intake. The small vacuum connector on top of the upper air intake hose behind the Mass Air flow sensor was cracked. I also found a leaky mess of coolant around the thermostat. I happened to have a new thermostat here and was removing the clutch fan and cover to access the thermostat. The clutch fan slipped from my hand and hit the ground breaking a blade off...Doh! So now instead of this being a 2 hour job its turned into multi day "wait for parts" job, LOL.
You can get by without the primary fan for a few days easy. Avoid stop and go traffic. Keep and eye on the temp and dont run the A/C.
On the bright side, those brittle fan blades would have broken eventually and probably cut a hose on their way off leaving you stranded.
