Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Ignition Coils
Anyone know how long the ignition coils normally last on the M52? My '99 323i develops a light skip after having been driven at highway speeds for a couple of hours. It's noticeable only after you've slowed down or come to a stop and then began accelerating again. The car has always had the same skip when you ended up in 4th or 5th gear at a low speed and tried to accelerate without downshifting, but grows more pronounced once having been driven at higher speeds for awhile.
I changed the plugs a few months ago since I had no record of when the last time it was done. I used the original equipment NGKs and the old plugs were a nice dark tan color with no signs of oil seepage into the cylinder and all were dry. Since it didn't cure the issue, I figured the coils might be the next place to start. They're the originals and the car had 152,000 miles on them. Am I looking in the right direction or does anyone know of any other sensors that might be causing the problem. O2 sensors maybe?
Old 09-01-2009, 10:25 AM
Jeron's Avatar
You problem may be a bad coil.
It is not unusual for a coil to go bad within 150k miles.
Without a CEL it will be hard to determine which, if any coil is bad.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-03-2009, 11:23 AM
