Having same kind of heating/cooling issue/ car overheats/ them doesnt ??????
2000 BMW 328i blows out cold air out of heater, and coolant residue is blow into the interior and on to inside of window. when i turn the car off it is lugging like a desiel truck. i have had therm, heater core check and there alright. please help, totally stumped???? |
How did they check the heater core? Did they pressure check the cooling system?
If you have coolant getting into the cabin, you have to have a leak at the heater core, or the heater valve, or the line between them. I have not fooled with the heater valve on my e46 and I don't recall noticing where it is. The usual cause of failure to heat is air in the system. |
| All times are GMT -8. The time now is 05:54 AM. |
