Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
Interior B Pillar Replacement
I have a 2003, 325I I need to replace the upper half of the Interior B pillar on the drivers side. I procured the replacement part from Pelican and am now trying to decide if this is something I can do myself. I have already replaced the A pillars. Does anyone have instructions on how to do this?
Old 09-29-2011, 09:01 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It should just pop off once you remove the top of the lower cover.
Old 09-29-2011, 09:23 AM
OK, I will ask the inevitable. How do you get the lower cover off? Also, what about the seatbelt that runs through the upper B pillar cover?
Old 09-30-2011, 11:35 AM
It just pops off.
One thing you should know, disconnect the battery and let it sit for at least a half hour if you plan on removing the seat belts.
Once you unbolt the lower part of the belt, you should be able to get it throguh the panel piece.
Old 09-30-2011, 11:37 AM
