-   BMW 3-Series E46 (1999-2005) (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/)
-   -   Leaking Temperature Sensor Fix (http://forums.pelicanparts.com/bmw-3-series-e46-1999-2005/729568-leaking-temperature-sensor-fix.html)
Manolito 01-19-2013 11:07 AM
When the temperature sensor in the lower radiator hose on the wife's '04 330i started leaking, I went crazy looking for an O-ring that would fit. I finally gave up and bought a new temperature sensor.
I just found a thread on another forum that indicates that o-rings of the correct size (or close enough, anyway) are available. o-ring #31
Ace Hardware sells a #31 o-ring for $0.59.
Home Depot sells #31 o-rings in pak of 10 for $1.79
I have not tried this personally, but I will definitely try it when my 325iT starts leaking, which it will eventually.
I actually looked at Ace Hardware when I was o-ring hunting. Guess I did not look hard enough.
